Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
3gs Static From Speaker, Then Reboots
Ok I have a 3gs 16gb that the sound is randomly cutting out. I get a loud static sound from speaker and then the sound cuts out. The phone then either reboots or just has no sound from speaker,mic, or earpiece. When I make a phone call the phone will connect but I cant hear them and they cant hear me.
I have since restored phone to factory and the phone still made same noise and reboot itself. I have updated software to latest version 4.3.5 but was occurring on 4.3.3 as well. I have opened phone to check connection of ribbon cables and all appear to be good. I checked for the two capacitors above the #4 cable and they dont appear damaged.
I've seen multiple posts with similar problems but no answers. As far as phone being opened replaced battery about 9 months earlier and had no problems with phone till recently. Phone was not dropped or wet. Thanks in advance, Steve
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Ordered up a flex cable and dock connector I'm hoping that will solve the problem.
von
Installed new flex connector and dock connector and phone seems to be working fine. Flex cable is a PITA to replace.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I do not know the answer to this multifactor problem, both speakers, sound, mic, shutdown etc. Most likely Logic Board. But some of the strangest problems of 3GS occur when the Flex Cable #3 is damaged or not inserted correctly (shorting system). I doubt this is the problem, but if you have the time and skill set, maybe replace #3. If it works great, if not, I warned you it was an out in left field long shot. If you decide to proceed before opening and during 3GS repair, make sure iPhone is OFF.
War diese Antwort hilfreich?
Bewertung 1
I have the same problem. So you sure the dock connector replacement fixed the mic, headphone jack, speaker issue?
Bewertung 0
I currently have the same problem. I changed the dock connector but didn't work.
Bewertung 0
Antwort hinzufügen
steve wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,451
