Zum Hauptinhalt wechseln
Das ist die Variante ausschließlich mit Wi-Fi der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7" Retina Display und einem 64 Bit A9 Prozessor.
Why is my iPad screen not working after replacing screen and battery?
After I replaced my iPad 5’s screen, battery, and home button assembly, the screen won’t turn on until it is plugged in. Once the screen is on, it is covered in vertical and horizontal colored lines and there is a vertical black strip roughly an inch wide going down the middle of the screen. I’ve already taken the glass screen and the lcd screen off and checked all the connections multiple timed and all of them seem fine. All of the cables are also intact as far as I can tell. I don’t think it’s a problem with the lcd either because the colored lines are fairly uniform and there aren’t any black blotches like I’ve seen in a lot of damaged lcd pictures. Is there anything else I can do?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It sounds like a bad connection. Get a magnifying glass and check all of the connections for damaged or bent pins. If they are fine try cleaning the connections with a qtip and alcohol and a soft brush. Make sure to disconnect the battery before you disconnect the screen.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lily R. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 90
