Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
Ipad 5 lcd useable in ipad 6?
Hi,
i was wondering if i would be able to use an lcd from my ipad 5 in my ipad 6?
Did anyone tried this before? Saw another post by someone but ifixit still lists them as compatible.
Any new attempts?
Thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I just tried to replace the lcd now and the lcd of the ipad 5 placed in the ipad 6 only shines light but does not give any image. The original broken lcd of the ipad 6 placed back in works and gives an image. So to me it seems like they aint compatible
von
Hi can anyone please help me if ipad air 9.7 inch (i.e.A 1474) screen digitiser compatible with ipad 6th gen (A1893)?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Yes. Even the iPad Air 1 LCD is compatible with both models too. Brightness varies though I don’t remember off the top of my head which one had a brighter LCD.
Quoting myself no this is not true. Only iPad Air 1 and 5th gen are compatible displays with each other.
iPad 6 requires the same model LCD can’t use other LCDs from 5th gen or Air 1. Must be 6th gen only. This is based off any seller other than iFixit listing it as 6th gen (e.g a1893 only).
Unless iFixit confirm and guarantee it’s iPad 5th gen / 6th gen hybrid LCD (somehow) works on the iPad 6 then I will say otherwise.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I edited my post see answer.
von
iPad 5th gen A1822 will not work in a 6th gen A1893
Bewertung 1
1 Kommentar:
I have a good LCD screen ipad6 and I want to replace that on my crack screen ipad5...will it work?
von
Ipad 6 screen seems to work on ipad air 1 but not the other way around. The screens i tested were a good ipad air which was flickering on ipad 6 and a cracked ipad 6 which seemed steady on ipad air 1, but i am not 100% sure about the second one.
Bewertung 0
Antwort hinzufügen
hilas1955 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 37
Insgesamt: 2,617
