Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für deinen Philips Fernseher.
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Hi,
What is the model number of the TV?
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
War diese Antwort hilfreich?
Bewertung 7
1 Kommentar:
So helpful, thank you!!
von
I found an answer, on my Mum's TV remote there is a language button, pressing it brings up the word English on the TV, pressing OK brings up a menu that defines the channels for the channel up and down buttons. Who knew that was there! It is very well hidden.
Once I found it fixing it was simple.
Bewertung 4
9 Kommentare:
I've been pulling my hair out for weeks and you've only gone and sorted it for me, I would never have found that, worked 1st time, thank you so much Mandy.
von
It's a terrible design to put that menu item there, glad you are fixed now.
von
Thanks, you have given me the answer too
von
Glad you are fixed too.
von
Thank you - one of life’s frustrations sorted 😎
von
4 weitere Kommentare anzeigen
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
Bewertung 2
3 Kommentare:
I have a Toshiba TV SUAZBe3DB and I have the same issue. Any tip please?
von
I also have a toshiba and have the same issue, please help!
von
I also have a Toshiba TV (only 2 months old) that's decided to do this, it's going through the window if I can't sort this, any help would be massively appreciated
von
Channel changers generally have a favorites position. It may be in that mode now.
Bewertung 0
Antwort hinzufügen
David James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 88
Insgesamt: 16,518
