Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare:
you fix this? i have the same problem
von
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
von
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
von
Einen Kommentar hinzufügen
2 Antworten
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
von
has anyone figured out what the solution is
von
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
von
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
von
sorry what do you mean, charge it fully then it will turn on? thanks
von
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
Bewertung 0
2 Kommentare:
Any updates on this? I have a s6 edge that this has happened to. I have a new phone to use and I just really want to atleast get the photos off of it. Ive tried all the button combos and other troubleshooting suggestions ive read, with no luck. Just now ive tried charging it with no response. I plugged it into my laptop and held the volume up and power button simultaneously, until a solid white LED light came on. Im not sure what this means. Is there anyway to get my photos?
von
Any updates? I’m trying to power on my old s6 and it did the same thing..
von
Antwort hinzufügen
Fix S6 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 68
Insgesamt: 11,142
