Zum Hauptinhalt wechseln
The Nissan Altima is a mid-size car which has been manufactured by Nissan since 1992. The Altima is one of the top selling Nissan models and primarily competes in the mainstream mid-size sedan class in the United States.
20 Fragen Alle anzeigen
3 windows don’t work
I have a 2008 Altima. Only the driver side window works. I used my key faub to get lower both front windows but only one will go back up. How can I raise the other window and what could be causing three of my windows to suddenly stop working?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @moshe1210 ,
Have you checked that the driver side Window lock button is not operated? If this button is operated it prevents all the other windows from working.
As can be seen from this image from the service manual, the BCM (Body Control Module) controls the operation of the power windows but both the rear windows and the front passenger window are also dependent on the driver’s window and door lock switch.
(click on image to enlarge for better viewing)
Here’s the 2008 Nissan Altima Model L32 Service Repair Manual Scroll down and click on the Power Window Control System link.
When the file opens scroll down to p.PWC-189 to view the instructions on how to test (and replace if necessary) the Main Power Window and Door Lock/Unlock switch.
Hopefully a start
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Thank you Moshe for asking this! And thank you jayeff for answering it!!! I have a Nissan XTerra 2012 and could not figure why I couldn’t get any of the other windows to work, thought fuse or switch. Didn’t realize I’d elbowed the button down on the child escape lock! LOL.
von
Same here. Thanks
von
Antwort hinzufügen
Moshe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 3,435
