iMac only white screen with chime
This iMac 17” 2006 when powered on has chime but only white screen, any solutions?
Ist dies eine gute Frage?
Generally a white screen issue is related to a failed hard drive.
Insert your original system installation DVD and boot holding down the “C” key. If you do not have that disk you need to have a system compatible external USB source to boot from. Another alternative is using another comparable MAC in Target Mode.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 71
1 Kommentar
Could you try the suggestions from this: https://blog.macsales.com/40844-how-to-r...?
von Jonas A.
