Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
iPhone 8 charge port, vibration, sound, and volume buttons not working
I have an iPhone 8 that I am trying to repair. The issue is that the charge port doesn’t work, the volume buttons don’t work, there is no vibration whatsoever (I have already checked the settings), and there is no sound. The phone will charge over wireless, however. Even stranger is that when trying to change the volume in control center, the slider is stuck at full volume and does not react to touch.
I was just wondering what part is the culprit. If the taptic engine goes bad, could it cause all this, or could all the malfunctioning parts be damaged and need replacing?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Do you know the history of the device like whether it was repaired before or went for a swim? A bad taptic engine would result in loss of vibration and “click” feeling from the home button when it’s pressed. You could try to replace the charge port to fix the sound issue but as far as the volume buttons those are a different assembly. Just make sure you source good parts and stay organized for these repairs as they require complete disassembly of the device.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
As far as I know, the phone has been dropped once, but in a good protective Otter Box like case. Other than that, the customer told me that the charge port stopped working on its own, and then one day he left it at home all day and that's when everything else went bad.
So you're saying that replacing the charge port could possibly fix the sound? I have no reason to believe that the volume buttons don't work, I just can't confirm that since the phone refuses to do anything related to volume.
von
@benstechrepair I would start with a charge port. The loud speaker makes contact with the charge port to make sound it is not directly attached to the logic board. I would see if you can pair it with a bluetooth speaker to check if the volume buttons work.
von
Antwort hinzufügen
Ben Masten wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 158
