Zum Hauptinhalt wechseln
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
20 Fragen Alle anzeigen
My lens will not retract when turned off.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
abcagle most commonly caused by a stuck lens. You should try the “tricks” mentioned on here. If that won’t work it is most likely that the lens is failing. You may need to either disassemble it and clean and inspect it, or replace it.
Ultimately it is also possible to replace the lens. Follow this guide Sony Cyber-shot DSC-W55 Lens Replacement
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
abcagle2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 437
