Zum Hauptinhalt wechseln
The LG 37LF65 LCD television, was released in 2007 and available in sizes: 32'' 37'' 42''.
Why is the LG HD TV display black and can only see a faint image?
I am an onsite engineer trying to rectify my end user who have problems with their LG HD TV.
When the LG TV is power ON, a light flashes on the screen then goes black but it’s a dark screen and I could vaguely see a faint picture on the screen.
Any advice on how can I able to resolve this issue.
Is it caused by a backlight problem of the LG TV?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @yjohari ,
Your TV model is an LCD TV so it will have fluorescent tubes for the backlighting and not LEDs. Having tubes means that there may be an inverter board for the tubes’ power supply.
Locate and inspect the inverter board for any leaking or bulging capacitors or other obviously damaged or stressed components. If nothing appears to be wrong it may be the connection to the backlights or in the panel itself. (See information in 2nd link that states that the tubes are EEFL type and are connected in parallel in the panel)
Here’s the service manual for the TV which may help. It also has a component parts list if you cannot determine what type of component a faulty component may be (look at component’s board designation) or its’ value and need to order a replacement.
Also here’s a link that describes what was checked on the same model TV having very nearly the same symptoms as yours.
Hopefully a start.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Yazidjohari51 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 24
Insgesamt: 444
