Zum Hauptinhalt wechseln
The Smart Oven® with Element IQ® is a trustworthy tool for the cook who wants a countertop oven that roasts succulent meat, broils, bake pizza, reheas leftovers and toasts evenly. Convection setting reduces cooking time by up to 30%. Model: BOV800XL
29 Fragen Alle anzeigen
Power but no heat - thermal fuse seems to be ok
Our toaster oven turns on and lights up but does not get hot. After some research I thought it might be the thermal fuse but after taking the dang thing apart the fuse seems to be fine when tested with a multi meter. So maybe it’s the heating elements but those are expensive and tough to get to. Before investing time and money anybody have any ideas about how to test if it is the heating elements? I mean, would they all go out at the same time? Other thoughts about problem.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Raphael Gutierrez verify your toasters make and model. Since you checked everything else already you could always check the heating elements.....
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I had the same problem. Upon examining the power circuit board there was a loose connection on one of the big elements, I think it was a relay of some kind. I added some solder and it's been working fine again for the last three months.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hey team toaster oven!! I have a problem with my start button…. It’s not working as much any more. It does work, kinda. Any ideas on how to fix this? Please? My best friend calls it the “magic oven”.
von
Antwort hinzufügen
Raphael Gutierrez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 99
Insgesamt: 2,095
