Zum Hauptinhalt wechseln
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73 Fragen Alle anzeigen
2011 F-150 V8 , coolant fan(high) runs all the time
I have a 2011 F-150 V8 w/150k mil. I have to replace water pump , also replaced hoses & thermostat . Everything went together well & runs fine . After driving it next day . I notice the coolant fan ( high sp fan, RS) runs all the time After engine get hot. Just curious if anyone had this problem .
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Did you drive for a long time the first day when you got your car after it was repaired?
von
No , I just did a test drive , to much sure everything was good . I did the repair my self
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello, Before you heat up your engine, I suggest to remove the terminal hose from which the water return back to the water tank, in general it’s the upper one (see image below), then start the motor and verify if there is a waterflow coming out from the hose, if there is water then your pump works fine otherwise it’s not or something stuck in the water circuit.
Assuming the water flows normally inside the engine and it stills heating up, then the first suspect is the thermostat blocking the path to the radiator you can check that by barely touching the radiator for a short duration and beware to not burn yourself and stay away from the fan.
The last thing is a broken radiator, something stuck inside avoiding water to flow through, remove the intake hose of the radiator and the water tank cork to allow air to escape, then blow air in the intake hose, if you see bubbles ns the water tank as strong as the pressure you put in it then that’s fine.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thank you for your help . I’ll check it out,, to make sure I got good coolant flow .
von
You're welcome, feel free to return anytime :)
von
Antwort hinzufügen
JWC64 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 81
Insgesamt: 6,496
