Is it possible to replace the glass only on the Late 2013 15 Inch?
Is it possible to replace the glass only on the Late 2013 15 Inch MacBook Pro?
I have a crack that doesn’t seem to be affecting the screen but on the “front glass” , was wondering whether it was possible to replace the glass only
Update (09/18/2020)
so this is the crack? will this eventually kill the entire screen, you’re saying?
I am beyond heart broken
Ist dies eine gute Frage?
Are you sure you have a retina model? The Unibody series has a cover glass which can break and not effect the LCD's image.
The retina series has a thicker LCD top glass which if cracked will fatigue the LCD back panel breaking the metal oxide etched circuity on it killing the panel. There is no fix other than replacing the panel or full display assembly.
von Dan
Simple way is to check the text below the display - if there's nothing you have a Retina
von amatsuda
I have the retina. What do you think of that crack? Will it kill the display? Do I have to replace it?
von bg234
It's just a matter of time the lower glass fails of the panel sandwich. Here's a teardown of the retina display your system uses MacBook Pro Retina Display Teardown
von Dan
