Zum Hauptinhalt wechseln
Das ist die LTE-Variante der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7 Zoll Retina Display und einem 64 Bit A9 Prozessor.
iPad Stuck in DFU Mode
I am trying to revive an iPad 5th gen wifi/cellular. Screen is black but when I connect to computer it is recognized as being in DFU mode by both 3utools and iTunes. Trying to restore on 3utools gives an error “ERROR: Unable to load RestoreRamDisk” and does not do anything. In iTunes when I restore it turns on with the apple logo and goes through the entire restore process, but when it is finished it goes right back to black screen and iTunes picks it up as being in recovery mode. Any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Anyone have any suggestions?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You don’t really say much about what happened to the iPad before trying to revive it but this is a logic board related issue. Something is going on with the NAND, either it is not powered correctly or it is corrupted in some fashion. During the startup phase (or any Restore/Update action), the device goes through a self test of all subsystems and in your case, the NAND is not responding.
Tell us more about the history of the device and we may have a more precise diagnostic but this will likely not be a DIY repair
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I got it the way it is so I don’t have a lot more info. It came in a lot that I bought of various devices and it was already in DFU mode when I got it. Thanks for the help I appreciate it.
von
Antwort hinzufügen
Robert Reich wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 51
Insgesamt: 1,300
