Zum Hauptinhalt wechseln
Convertible 2 in 1 Touchscreen Laptop released in 2012 by Lenovo.
3 Fragen Alle anzeigen
wireless adapter replacement Lenovo twist s230u
replacement guide request for wireless card adapter
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
Which wireless card do you mean, the WLAN or the WWAN?
Here’s the hardware maintenance manual for the laptop, taken from this webpage (select 3rd page of results for guides at bottom of the list)
Go to the bottom of p.64 to see the necessary pre-requisite step and then the procedure to remove/replace the WLAN card.
Go to the bottom of p.65 to see the necessary pre-requisite step and then the procedure to remove/replace the WWAN card.
Here’s an image from the parts list for the 2 model variants of the laptop showing the part numbers for all the various WLAN cards compatible with both the laptops. As the part numbers are identical for both model variants they will work in either laptop.
(click on image to enlarge for better viewing)
The part number for the WWAN card is 04W3786. It is the same for both laptop model variants
If you search online using the part number only in the search box of your browser you will get results for suppliers of the part.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Dormouse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 319
