Zum Hauptinhalt wechseln
How would I fix this laptop screen case?
I got a Lenovo laptop through DSA last year. The warranty has just run out, but the plastic case is starting to pull away at the side. There are no cracks in the case. It’s just falling apart through general wear and tear, which seems to be a very Lenovo-type thing to do, apparently. I’ve included an image of what I’m talking about below. It might be nothing to worry about, but I’m hesitant to let it get any worse as I still need it for several more years of education. Would it be OK to glue this?
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
I can't make out the image too well, is it separating on the bottom?
von
@gatewaynomad No. it’s straight up along the right side of the screen. The front of the case has cleanly separated from the back. No breakages. I’m guessing that some glue softened and it came apart.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hi @sebaren ,
You may also wish to consider replacing the lid cover if nothing else works satisfactorily.
Here’s the hardware maintenance manual for the laptop, taken from this webpage
On p.63 you’ll find the necessary pre-requisite steps and then the procedure to remove the LCD unit. This will allow you to replace the lid cover.
On p.85 Item #7 you’ll find the part number for the cover. If you search online for 5CB0R28213 you will get results for suppliers - example only. There are other suppliers that may suit you better. It was only shown to give you an idea of the cost of the part.
War diese Antwort hilfreich?
Bewertung 2
Given the information you have given me, I would say it shouldn't effect performance, as long as you mind how you handle the screen when opening and closing.
If I am seeing it correctly, then a little double-sided tape might be a better bet, but I am not sure that I am seeing it correctly.
In my experience, as long as it isn't separating near the hinges at the bottom, it's not normally too big a deal. Taking care when opening and closing the laptop can extend the life quite a bit. hope this gives you an idea what to expect, sorry I couldn't help more.
Bewertung 0
1 Kommentar:
What can one do when the it is separating near the hinges?
It's about €100 to replace the bottom casing. Never mind a new battery of similar cost and the labour!
If only I'd known I would have spent it on a better laptop. Hindsight is foresight!
von
I have the same problem!! But it’s caused by the pathetic little plastic clips they designed to hold the plastic casing together just breaking off one by one. You can hear them rattling around in the casing and eventually it opens up enough for them to start falling out!
My bottom right side started first, now the entire hinge section is loose and the opposite side of the screen is completely pulling apart!
Have tried duct tape to keep it together but it’s not strong enough. So what does one do now?! It’s not a fixable problem as they surely can’t give you a new casing? I am so disappointed as I’m fine with the most of rest of the laptop (the screen could be better but I can live with it), except the battery which has already died!
And it’s only 1y 5m old! If only I had known…
Bewertung 0
1 Kommentar:
PS: I can't even open and close the screen anymore. Do I now have to get a monitor and a keyboard and use the laptop as a my tower?
I'm just feel so frustrated and disappointed with Lenovo. Got to give it to them for being able to produce something that just manages to outlive it's warrantee though!
von
Antwort hinzufügen
Sarah Johnston wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 414
