Zum Hauptinhalt wechseln
Apples Nachfolger des Dock Connectors. Dieses Kabel wurde seit 2012–2021 mit den meisten mobilen Apple-Produkten mitgeliefert.
How do I restore the lightning connector surface when it wears down?
I frequently have lightning connectors that don"t reliably connect to an ipad or iphone and it seems like the surfaces of the connector are worn down. Is there a way to restore the surface to make a reliable connection again?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
had you some answer? I got so many lighting cables worn out on the pins without repair posiibility, and I feel that maybe one devide worn out quickly
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Good afternoon Bill!
Over time lightning cables can lose their effectiveness if the contacts are dirty/worn off. If the gold contacts are still present on the cable, you can use some high concentration (I use 99%) ISO alcohol to clean them. If the contacts are gone, its sadly time for a new cable. Also sometimes your charge port can have some debris in it. If your charging cable does not go in all the way and make that wonderful “click” sound then you can take a toothpick and CAREFULLY scrape the port away from the contacts. If you do this, please be very careful with the contacts as to not bend them. I hope this helps!
Roy
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
i have yet to try this, but i expect microsoldering paste on the contacts will puff it up enough to make contact even with sloppy older ports. it was always a bad design idea - the inner contacts are just wire pins that are inevitably going to fatigue and hey saggy with use.
yet another example of apple screwing users with equipment that will fail and is very hard to replace, just to be awful.
disregard all comments shaming and blaming you for what apple designed to happen
von
Sadly you really can undo the damage. This gets into the handling and storage of the cable.
Don’t touch the connector ends with dirty hands the grime and acids/salts in your sweat can damage the finish and the grit will act like sandpaper. Use a isopropyl alcohol wipe cleaning the ends when they become soiled.
As for storage I recommend a simple sailers coil method as outlined here The trick to coiling lines Unlike a rope we don’t tie it off, instead a velcro loop tie is used. You don’t want to knot the cable just a simple round coil, held by the velcro tie.
Use a Nylon mini stuff sack or Rugged plastic pouch to hold your cables.
Bewertung 1
I was wondering if putting some solder on them too would work.. I don't c why not. Kinda weird all the answers were more of the opinion for well exactly what this company is NOT about lol ...I'm gonna try it. I'm so sick of sacrificing logic and reason and the planets plastic pollution issues for my privacy.
Bewertung 0
Antwort hinzufügen
Bill Guppy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 107
Insgesamt: 8,580
