Zum Hauptinhalt wechseln
Repair and additional information for the Samsung Refrigerator RFG295AA**—a 2010 bottom freezer model with ice through-door feature and both drawer and door access convenience. This page covers information for model numbers matching the pattern RFG295AA**.
Samsung Freezer Not Cold Enough
I have a Samsung French Door Refrigerator / Freezer. The temperature is reading -8 degrees F but the actual freezer temp is +20 F. I replaced the sensor but still doing the same. Refrigerator is holding temp at 34 Degrees F. Any thoughts?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @tommylam143 ,
What is the model number of the refrigerator?
von
It is a Samsung model RFG295AARS.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @tommylam143 ,
Looking at the parts for the refrigerator, it has an evaporator unit in both the refrigerator section (part #19) and the freezer section (part #14-6).
Is the evaporator unit in the freezer compartment icy cold? Be careful if you go to touch it with your bare hands.
If not there is a problem in the sealed system.
How old is the refrigerator? According to the owner manual (see p.37) there is a Five (5) Years Parts and Labor Warranty on Sealed Refrigeration System Only* (*Compressor,evaporator,condenser,drier,connecting tubing)
War diese Antwort hilfreich?
Bewertung 2
10 Kommentare:
Sorry, but I'm still learning how to use this forum. Yes, the evaporator is icy cold. I'm just really puzzled why the sensor is indicating such a different temperature than the actual temp of the compartment; however, the sensor is clipped on the evaporator coil tubing so it's reading that temp vs the air temp in the main compartment. I'm going to recheck the operation of the fans to make sure they are working properly?
von
@tommylam143
Was the sensor, part #13-1 in the freezer section the one that you replaced?
Sounds like you're talking about the defrost sensor (part #14-2) as it is clipped to the evaporator coils. It is used to signal when the temp is 29 F (or thereabouts) to end the auto defrost cycle so that the compressor is restarted so that everything is cooled back down again, not to indicate the normal operating temp of the freezer. The operating temp sensor is part #13-1
Here's a link to the service manual if you wish to buy it. Have noticed with other Samsung fridge manuals that they give the resistance values of the thermistors (temp sensors) for the temps from about -50F to +50F so that they can be measured and checked if they are OK or not at whatever temp. Just some thoughts.
von
@jayeff Aaah! I think that might be the problem (changed the wrong part)! I'll let you know the outcome. Thanks so much for your help!
von
Hi @jayeff,
I ordered and replaced the freezer temp sensor part #13-1 and the problem still remains . I have also ordered the Service Manual and am anxiously awaiting its arrival.
The really intriguing part about all of this is how the freezer temp control system is behaving. I can raise and lower the setpoint on the front control panel and the freezer temp as indicated on the panel will indicate it is following the setpoint; however, the actual temp in the freezer as indicated by a thermometer remains around +20 to +25 degrees F, and a bottle of water will barely freeze. Right now, the panel is indicating that the freezer is holding at -14 degrees F, but the actual compartment temp is +25.
The parts I have changed to date are Sensors #14-2 (in error) and #13-1 as well as both the Inverter Board #31 and the main ECB part #30. The boards were changed fairly recently, due to other issues with the cooling of both the refrigerator and freezer compartments. Refrigerator section is working fine now.
von
@tommylam143
Hopefully the service manual will shed some light on this.
Did you check if the evaporator fan in the freezer compartment is operating?
Not sure with your model but with a lot of fridges if you manually operate the door switch you can feel the fan operating with the door open as the fan is stopped when a door is opened to prevent the cold air being blown out of the compartment.
By manually operating the door switch you fool the control board that the door is shut and the fan is restarted.
My thinking on this is that the temp at +20-25 may just be the temp that is produced by the cold emanating from the evaporator unit and not what is produced when the air is circulated over it continually therefore driving the temp down as the colder air is passed again and again over the unit.
This doesn't explain why the control panel shows that it is colder than it actually is though
Also -14F to my mind is way too cold a temp. I thought freezers were normally at 0F (mine is set to -18 C which is ~0F) or thereabouts, but perhaps that may just be location. 0F is 32 degrees below freezing therefore -14 would be 46 below. Hopefully the service manual will show what the max freezer temp is
von
5 weitere Kommentare anzeigen
Antwort hinzufügen
Tommy Lambright wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 2,553
