Zum Hauptinhalt wechseln
A1706 / EMC 3071 - herausgekommen im November 2016. Dieses 13" Macbook Pro führt die OLED Touch Bar ein. Es bietet einen Dual-Core "Skylake" Intel Core i5 CPU und vier Thunderbolt 3 Ports.
239 Fragen Alle anzeigen
Some tiny pieces fell of from my MB
Hi,Some tiny piece fell off from the logic board. 1 black IC and three silver capacitor I think! Can be fixed or not!!
I think it's “ zdw1 6af s019 “
It's turn on with max fan speed and very laggi (unusable)
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi! I'm facing this issue too. Were you able to get it fixed?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It can be fixed but will require someone with a surface-mount soldering station. A good repair house should be able to do it.
Did something happen to make these parts come loose?
Update (09/26/2020)
The orientation of the chip should be marked on the chip and the board. The other components will be hit and miss. I would definitely price out a replacement motherboard and compare it to a probable pricey repair.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@crowbot This happened after opening the laptop, and I'm not even sure what part this IC is for! And I do not know the capacitors is for which part, do I need to change the motherboard (logic board)?
von
Hopefully you have all of the pieces! Yes, these can be resoldered to the logic board by someone with the proper skills and tools. This is beyond what a DIY can do as the tools needs are specialized and you need access to the schematics and boardview drawings.
How did they come off is also important! I’m suspecting you poked too deep with your tools to pop the bottom cover off. You may have caused other damage and the one or more of the parts could be damaged as well.
Bewertung 0
2 Kommentare:
von
You need to get them put back! But just like a jigsaw puzzle there is direction and placement issues! You just can't put the parts any which way! You need the proper tools and the documentation to guide you (Schematics and boardview drawings).
Your other solution is much more costly! Thats replacing the logic board completely!
von
Antwort hinzufügen
Bl4ck 4lien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 177
