Zum Hauptinhalt wechseln
Angekündigt im August 2017. Das Galaxy Note8 ist der Nachfolger des durch Rückruf bekannten Galaxy Note7. Erhältlich war das Note8 im September 2017.
145 Fragen Alle anzeigen
Poor performance after battery replacement
I replaced my battery with a new part from a reputable UK seller, and the device continued to operate fine for two weeks, however the battery calibration appeared to fail a couple of days ago and now the device is running at approximately 1% of the expected performance when on battery (5+ minutes to boot as opposed to a few seconds), and yet when connected to the charger it runs fine again. Do I have a faulty battery?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Alistair,
Good afternoon! I have seen this issue many times with replacement batteries. More than likely you did get a defective battery. Check with the seller to see what their warranty period is and try to get a replacement. I just had a note 8 do this same thing a few weeks ago. Hope this helps!
Roy
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks Roy, I was hoping this wasn’t the solution but I’m inclined to agree with you - Back through the layers of adhesive again I guess!
von
Antwort hinzufügen
Alistair McShee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 74
