Zum Hauptinhalt wechseln
Reverse osmosis units are common water filtration solutions found under sinks in kitchens.
Why is my water filter so low?
We have a Profile Reverse Osmosis Water filter in our sink as a water softener. We recently saw a problem with the water speed as the flow rate decreases after a couple seconds to a drip. I was thinking we might have to reset the filter but Im still not sure. Do you guys have any tips to fix this issue? Thanks in advance!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi , check to see if the tank is full , if it is and the water flow cuts off chances are that there is a problem with you tank blatter and will need to replace the tank. there is a valve located on the side of the tank and pressure should be around 6-7 pounds. Granted the r o will produce soft product water but if your wanting the whole house water softened a water conditioner softener is the solution, ro is usually used at point of use ex. kitchen sink whereas the softener is a point of entry system servicing the whole home.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Suchit Bandaram wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 244
