Zum Hauptinhalt wechseln
The Samsung Galaxy A10e is a lower-mid range Android device released by Samsung in February 2019. Identifiable by model numbers SM-A102(U, U1, W, or DL).
Are the guides for the Galaxy A10 applicable to the Galaxy A10e?
I can't find a guide on this site specifically for the Galaxy A10e. Is it ok to follow the guides, specifically the screen replacement guide, for the very similar Galaxy A10?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
This may be a silly question but just curious. Can you fix the Samsung Galaxy A10e after you get it wet? I have a spare but wanted to double check before using it.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Youtube can be a great thing as well: https://www.youtube.com/watch?v=x7Ui_KZf...
Good luck!
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
Thank you so much!
von
Hi Kenneth,
I just had the opportunity to repair the charging port on an A10e, so published a guide for that. In terms of internal layout, the A10e is nearly identical to the A10; the only important difference is that the motherboard cover is in two pieces on this phone that both need to be removed, as opposed to the single piece on the A10.
Hope this helps!
Bewertung 4
Antwort hinzufügen
Kenneth wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 597
