Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Frage geschlossen
I cannot hear the person Im calling?
I have replaced my rear panel and front assembly, everything is perfect but when I make a call I cannot hear the other person. If I press speaker then I can hear.
I took apart iPhone and made sure connector 1, 2 and 3 were seated correctly as this are the only thing I can think of.
Done this 3 times with no success....
Ok, it is connector 3 thats the problem, I have inserted it in several times but no joy. Is it possible that the from assembly I got on ebay is faulty or is the connector on my logic board faulty.
So Ive figured out the digitiser has nothing to do with it as connector 3 is not even part of it. Its the middle frame assembly that has connector 3. So can someone please tell me how to remove the earpiece and connector 3 on the frame.
That sounds fine but now Im thinking it could be the connector 3, the fps connector. How can I tell if it needs replaced as this is the connector for the earpiece and proximity sensor and this is also not working.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You can change the whole midframe. Its alot easier to do compared to changing just the earpiece. Ive tried to change just the earpiece and havent been successfull. I would suggest buying a midframe from eBay or something and heating the digitizer off the midframe then gluing onto the new midframe.
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 784
