Icemaker wont produce ice
If there is no flow of water to the ice maker what is the failing component that caused this?
Ist dies eine gute Frage?
If the water inlet valve is defective, or if it has insufficient pressure, it won't allow water to flow through. As a result, the ice maker won't make ice. The valve requires at least 20 psi to function properly. Make sure that the water pressure to the valve is at least 20 psi.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 74
1 Kommentar
@yarddawg what is the exact model number for your fridge?
von oldturkey03
