Zum Hauptinhalt wechseln
Das Pixel der dritten Generation wurde von Google im Oktober 2018 veröffentlicht.
104 Fragen Alle anzeigen
Is there a possibility to change front glass with LOCA?
Is there a possibility to change the front glass Google Pixel 3 by the help of LOCA UV glue, instead OCA glue?
I’ve bought a LOCA glue, LCD separator.. and now thinking about, which is better: 0.03mm or 0.05mm tungsten wire for separation is better? In the end, when i’ll separate the cracked glass, can i apply a LOCA glue on the POLED matrix to attach a new glass? Looking forward for your answers!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
I would go with the thinner wire because OLED is extremely fragile and it’s very difficult to do glass only repairs on OLED panels unless you’ve got the proper tools. Just today I decided to attempt a glass only repair on an s9 plus display I had on hand and ended up damaging the OLED panel. I was using a razor blade but I learned that prying up on the glass made it worse.
War diese Antwort hilfreich?
Bewertung 0
As i understood, prying up must be done only with the help of OCA film… its safer…
So sorry to hear, that you couldnt repaire your phone…
Bewertung 0
Antwort hinzufügen
Alexey Loom wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 173
