Zum Hauptinhalt wechseln
Released in 1988 as the successor to the SHS-10
1 Fragen Alle anzeigen
Left channel sound low and hissing
The left channel is not changing volume and is stuck at being very low, it is also quite fuzzy. I can only hear any sound from the keys on that channel if I turn the volume all the way down as this stops any sound coming from the right channel.
This applies to the inbuilt speakers and the headphone port.
I’ve replaced all the capacitors and even the amp but it hasn’t fixed the issue. I think there might be a short somewhere on the board before the output is split but I can’t see anything.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I also have an issue with mine
von
I just bought my shs 200 and suddenly the keys stopped working and when i try to play the built in beat sound thingy it'll glitch in and out and then eventually stop. HELP
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I followed the traces, seems that the issue is the potentiometer used to change volume, there’s a break in one of the slides.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Joined the channels at the input and output on the pot, both speakers now working.
von
Antwort hinzufügen
Jacob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 114
