Zum Hauptinhalt wechseln
A Dell XPS 15" 9575 (2 in 1) laptop, manufactured in 2018.
Replacement screws for laptop base.
I’m having difficulty identifying the screws that fit the base of my Dell XPS 9575 2-in-1 Laptop. I need to have them replaced as I’m missing some and some of the screws are becoming loose to the point where tightening them to the point of almost stripping them isn’t doing a thing. Anyone know where I might acquire the item in question? Any help will be much appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @creativechef253 ,
Here’s the service manual for the laptop, taken from this webpage.
On p.10 it shows that 8 M2 x 3 Torx head screws are unscrewed to remove the base cover.
Here’s just one supplier. Alternatively just search for T5 2mm x 3mm screws to find suppliers that suit you. (being Torx head would be up to you as it is the size that matters i.e. M2 x 3mm and not the screwhead type and your local hardware store may carry them)
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@jayeff Thanks for the assistance. Very Much appreciated!
von
Antwort hinzufügen
Craig Bowser wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,190
