Zum Hauptinhalt wechseln
1,83 GHz Core Duo oder 1,83, 2 oder 2,16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Fragen Alle anzeigen
Why is my hard drive not recognized?
I installed a crucial MX500 SSD on my 17" iMac Core Duo computer. I created a bootable USB for macOS X Catalina. When I start up the computer holding down the option key, an image that says “Install macOS Catalina” appears and after clicking it, nothing happens. I waited all night and nothing.
Please help.
Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The EMC 2104 is limited to
Pre-Installed MacOS:X 10.4.4 (8G1165)Maximum MacOS:X 10.6.8*
Go here and look up your machine and it will tell you the highest operating system your machine will take.
https://everymac.com/ultimate-mac-lookup...
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks a lot! I'll try it and let you know.
von
@ruvelsa - Sadly the Crucial MX500 SSD won't work in your system as the systems SATA port is only SATA I (1.5 Gb/s) You'll need to use a Samsung 860 EVO SSD unlike the Crucial drive which is a fixed SATA III (6.0 Gb/s) the Samsung is auto sense so it will dial down the data rate to what the system can support in this case SATA I (1.5 Gb/s).
von
Antwort hinzufügen
Ruben Velez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 52
