Zum Hauptinhalt wechseln
Abgesehen von der Tahoe Limited Edition wurde das Fahrzeug für das Modelljahr 2000 auf der neuen GMT800-Plattform neu gestaltet, die weiterhin mit den Pick-ups und SUVs in Originalgröße geteilt wurde.
Why does my brake pedal go to the floor when the engine is running but
when the engine is running, my brake pedal goes to the floor. when engine is off, I can pump up the brakes somewhat. I have changed the master cylinder and there is no fluid leak. Could the problem be with the power assist boost, or is there something else that could be the issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare
My brake pedal go to the floor it stop the car but with the pedal tolow
von
Hi I have a 2004 dodge dakota,Replaced (rear break lines rear rotors ,calipers,pads front calipers ,pads ,master cylinder, and brake booster.Bled out all air have a good hard up top pedal when truck is off .As soon as started pedal goes to the floor ? Why why ? Also the new booster check valve has three holes the old one only two.??
von
Same here mk4 bora nightmare spongy brakes im on the edge of a meltdown here 😢
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi @kyvic,
What is the model year of the vehicle?
I don't know the vehicle but reading online it seems that it may have either a vacuum brake booster or a hydraulic brake booster given what booster part types are available.
If the brake pedal sinks to the floor when the engine is running then there may be a problem with the brake booster. Here’s a video that may be of some help for a vacuum brake booster. At 3:30 minutes into the video it describes why the pedal may go to the floor - faulty poppet valve in the booster.
Here’s a link that details how to test if a vacuum brake booster is working properly.
I don't know about a hydraulic brake booster but here’s the 2007-2009 GMC Yukon Service Repair Manual + Owner’s Manual. I realize that this is out of the model year range that you selected but in the Brakes > Hydraulic Brakes section, it describes the operation and repair of the hydraulic brake booster. Hopefully it may be the same for your year model.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
I have a 2000 ford excursion gas engine. I have been battling trying to bleed the brakes. I have dumped 4 gallons of oil through the line. Changed calipers, checked vaccume lines, the pedal gets stiff while pumping but goes to floor when starting. Still cannot get air out of lines. Is there another way to test the booster that I can do? So far everything seems good. Cannot find a leak anywhere. I don't loose fluid while it is sitting, or while I pump the pedal. I do not have a scan tool to activate the abs but scan tests good. Any help would be great. I don't have the money to have towed to a garage and repaired. Thank you
von
Not sure if directly helpful to you but perhaps to other ford owners: forscan is a free app that supposedly has a brake bleed component
von
A brake pedal going to the floor could be indicative of having air in the system still. These can be notoriously hard to bleed all of the air out. The air will get trapped in the ABS pump and will give you a dodgy pedal. I have found activating the ABS system will help to shake the air out. There is a special bleed procedure dealers perform with their scan tool in order to activate the pump. You CAN, although I do not recommend, find a place to jam on the brakes to activate the pump and then rebleed.
If you cannot get a pedal at all, make sure you do not have another leak still, some can be harder to find as they will spray higher up or dribble along the pipe and not drip. If you got a refurbished or used M/C I would double check it to make sure its not internally leaking. They can also leak into the booster hiding a leak.
good luck
Bewertung 1
3 Kommentare:
,,, whilst searching for a solution (however not yet found) my mechanic disconnected the master cylinder from 'under the bonnet' feed and fitted 2 bolts instead to tke master cylinde, psdal was tight and didnt budge, therefore eliminating the possibility of air bubbles - nof surs if this helps.
von
How would u do this at home? I'm dealing with this brake issue and it's frustrating... My first time doing them on my own
von
@Zykearia Hyman You are doing what to which vehicle? Give more information so you can actually get more help. What are you trying to do? What make/model/year is the vehicle?
von
Have same problem it turned out bleeder screw snaped changed new cylinder and bleed that line was too much air traped there after that. No more spongy brake
Bewertung 0
1 Kommentar:
Air trapped in cylinder reppace cylinder then bleed that line
von
Antwort hinzufügen
Vic Hodge wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 23
Letzte 7 Tage: 150
Letzte 30 Tage: 725
Insgesamt: 75,436
