Zum Hauptinhalt wechseln
Reparaturanleitungen und Demontageinformationen für Android-Handys aller Formen, Größen, Farben und Marken. Hol dir alles, was du zum Reparieren brauchst.
33691 Fragen Alle anzeigen
Can I do repair when the phone is not completely turned off?
I'm trying to repair a phone which has a broken power button. I managed to get the phone turned off but it just turns straight back on again because of the broken button. Is it safe to try to take the phone apart when it is in standby or should I just wait until the battery dies? Taking it apart would involve using the iopener to melt the adhesives.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I would not recommend that, due to the possibility of a shorting something out, specially the battery. It is highly recommended that the device you will be working on is to be powered down.
As an optional thing, which I also recommend is to ground yourself with an Anti-Static Wrist Strap, to better protect both yourself and your device.
When you are working on the device, be care to disconnect the battery without puncturing it, as that is the fastest way to start a fire. So, again, power down the device, if not possible let the battery deplete. Then open the device, disconnect the screen and disconnect the battery.
Any questions, let me know.
Alex H.
War diese Antwort hilfreich?
Bewertung 2
Just be EXTREAMLY careful, don’t touch or poke anything, it’s risky, but it can be done
Bewertung 0
Antwort hinzufügen
Tobey B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 39
