Zum Hauptinhalt wechseln
Apples vierte Generation ihrer Smartwatch, mit optionaler Mobilfunkverbindung, veröffentlicht am 21. September 2018.
124 Fragen Alle anzeigen
Apple Watch freezing every time
My Apple Watch series 4 freezing every time , sometimes works perfectly for couple of hours
I’m unpairing repairing every time
hard reset can’t resolve this issue
I tried with several iPhones & updated Watch os
still same sometimes Digital Crown stopped working
screen is always freezing how can I fix this
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
That sounds like a logic board issue, your best bet may be to try swapping in some parts but if that doesn’t work you might have to buy a new watch.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Which parts needs to be swap
von
everything except the logic board
von
I replaced the screen & new battery still problems persisting
von
said everything, not just screen and batt
von
If you are still having issues, try this.
  1. Force restart the device (hold the crown and power button)
  2. Once the device turns off, let go of both buttons. When the apple logo appears, hold the power button (lower right one) until the erase all content option appears
  3. Follow the prompts and allow the device to reset.
  4. Pair the device again
Hope this helps!!
Bewertung 0
1 Kommentar:
I tried several times
It was working for week then goes to freezing again
von
Antwort hinzufügen
Shaheen Sultana wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 166
