No sound during call
Hello guys! Recently my iPhone started behaving strange. When I try to call someone from contacts the phone stays in contacts, but actually calls in the same time. Also when someone calls me i can’t hear them and they can’t hear me. In all other circumstances the mic and the speaker are ok. What may be causing the problem?
I tried with a different antenna, but it didn’t solve the problem. Thank you in advance!
Dan
Ist dies eine gute Frage?
Can you hear them when you switch to loudspeaker?
von Roman Prochazka
No, I hear no sound on loudspeaker. Even with headphones, except the clicking sound of inserting the headphones into the headphone jack. I am not an expert but I think it is some sort of Audio IC issue.
von Yordan Yordanov
Sure could be an Audio ic issue, in which case it's not worth fixing
von Roman Prochazka
@pomikoli i second this, definitely audio IC not worth fixing unless you know SMD and the phone has sentimental value.
von Owen Wadsworth
@dan2002 Have you ever tried with a earphone, is that working?
von Albert
