Zum Hauptinhalt wechseln
Zubehör für Microsoft-Spielekonsolen. Die Reparatur von defektem Zubehör für die Spielekonsole ist mit den richtigen Werkzeugen problemlos möglich.
131 Fragen Alle anzeigen
Xbox one Elite 2 controller missing components near right joystick
Hello,
I’ve got a problem with an Xbox Elite 2 Controller. I replaced the right joystick and it works fine except that it does not register a button press of the right joystick.
In the process I may have knocked off two components right next to it:
Any help with identifying the missing components and what to replace them with is much appreciated.
Update:
I really want to know, so I got my hands on another one of these that needs fixing for a good price. This is what the components look like:
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
If anyone cares, I managed to fix it. The lower component is a 32 ohm resistor. I just searched old junk PCBs and took one that fits. The upper component is a diode and this one is not critical.
Also there was a broken trace, so I soldered a jumper wire from the button switch to the 32 ohm resistor and everything was working ok then. I skipped replacing the diode because it’s too much trouble in that awkward spot with the broken trace. No clue what the diode is there for.
Desoldering that joystick module was a PITA because the PCB somehow eats up a lot of heat. Much more annoying to work on than the previous controllers! Now all is good :-)
War diese Antwort hilfreich?
Bewertung 2
Probably the same as the capacitor next to it. usually when a component forks off in two directions like that the caps are identical.
Bewertung 0
2 Kommentare:
Hi there, thanks! I uploaded another picture with the two components on the board. The component looks different than the cap. Could it be a resistor? The one above it is a small black box, a bit taller than the cap. It's connected by two traces. Could it be a diode maybe?
von
i cant really tell what it is in the second photo, to blurry. It kinda looks like a switch,
von
Hey Chris,
Thank you for posting this! Because of you I was able to fix a elite 2 controller I bought for a good price to fix. I had given up because there were some components missing but because you found out it wasn't a necessary component I just put in New sticks and tried it and voila it works again. Now I need a new battery because the one that is in there is swollen. Anyways thanks for all your hard work it has really helped me with my controller :)
Bewertung 0
Antwort hinzufügen
Chris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 315
