Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
465 Fragen Alle anzeigen
CPU 300% & 100% Exhaust Fan after light water spill on keyboard
A small amount of water was spilled on the keyboard/trackpad. It did pool briefly until it was wiped off.
Since then, the cpu is around 270% and exhaust is 100%.
Running diagnostics, I get the following codes:
Reference Code: PFM006 & PPN001
I bought the screw driver set and removed the bottom cover, everything looks really clean. I tore it down completely and I don’t see any corrosion or water damage.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Focus on the logic board following this guide: MacBook Air 13" Mitte 2013 Logic Board Replacement. I’m sure you’ll find corrosion staining on the other side. Post a clear image of any areas you think need attention Bilder zu einer vorhandenen Frage hinzufügen
MacBook Air 13" Mid 2013 Logic Board Bild
Anleitung
Schwierigkeitsgrad:
Mittel
2 hours
iFixit Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
2 - 5 minutes
War diese Antwort hilfreich?
Bewertung 2
13 Kommentare:
Thanks, I tore it down and uploaded some pictures, I don't see anything obvious but I'm not sure where I'm looking for temp sensor or whatever is causing it to think it is overheating.
von
Well the good news I don't see any staining on the logic board around the SMC which is what I had feared.
That pushes to the trackpad as the likely area. While not clear in your pics I do see salting on the solder joints and staining. So you'll need to replace it at this point MacBook Air 13" (Mid 2013-2017) Trackpad and here's the guide MacBook Air 13" Mitte 2013 Trackpad austauschen. If the cable has staining you'll need to replace it as well MacBook Air 13" (Mid 2013-2017) Trackpad Cable
von
I never got notified you responded.
Is it something I can try cleaning connectors first? The circuitry I can see looks really clean.
Do you know what part of the trackpad is the circuitry for the sensor?
von
@billybobtimmy - Cleaning is always iffy on a trackpad. Replacing is the better direction. There was enough staining that you would have needed to desolder components to get under them to clean.
It all comes down to skills, time and costs!
von
I just took out the trackpad and will order a replacement, but I am confused, it looks spotless. It is where the water was pooling for a brief second, but I see no signs of water, corrosion or damage. It looks brand new.
Is the thermal sensor on the trackpad board? Seems an odd component to control that but I have seen other posts list the same thing as the source of the problem.
Thanks for your help by the way.
von
8 weitere Kommentare anzeigen
Antwort hinzufügen
Christopher wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 106
