Zum Hauptinhalt wechseln
Popular clothes dryer series by Kenmore.
60 Fragen Alle anzeigen
Why is my dryer not heating?
We have a whirlpool dryer older model. My husband has tested EVERYTHING for continuity, everything seems to check out fine and getting electricity. We just 2 weeks ago cleaned the venting system out because the dryer stopped working all together, we replaced the thermal fuse and it started working again. But Now it runs but doesn’t heat? We have pulled the motor out as well and that’s getting continuity as well. Is there anything we are missing here? Please help!
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
HI @grayashlyn38,
What is the model number of the dryer?
von
@grayashlyn38 we would need to know exactly what was tested. What concerns me is that the thermal fuse needed to be replaced. Have you checked the heating element (this is an electric dryer, correct?). Like @jayeff mentioned already, we will need to know the exact model number for your dryer.
von
Thank you!^ unfortunately ours is electric, we’re gonna try a few more things out tomorrow and if not I’m about to throw the whole dang thing away lol!
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Make sure you have 240v AC coming to the dryer before you throw it out. Could very well be an issue in the outlet or the breaker box. The dryer will run like normal - but no heat at all. Very common that I diagnose brand new dryers not heating and find that to be the case:)
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
This is a gas dryer
von
@Lee Dunn as the OP stated in a later comment "Thank you!^ unfortunately ours is electric, "
von
I had a similar problem with my dryer. If yours is gas, one of the most difficult to troubleshoot issues is the gas solenoids. When cool (no heat from burning gas or heat from being powered on) they test out normally. Perfect conductivity and ohm readings. But as soon as they get hot enough, the connection breaks from the wires shifting around inside them from heat and gas stops flowing. It took me so long to finally figure that problem out on my dryer. If you haven’t replaced them yet, I’d highly recommend doing so. They’re quite inexpensive too. Make sure you get both of them though! (there’s two, I don’t remember why).
There is also a flame sensor and an ignitor on most gas dryers. Again, if you have gas, make sure to check those too.
Bewertung 0
1 Kommentar:
@grayashlyn38 Unfortunately in your case, it might be something similar to the solenoids, but instead with the heating coils. Otherwise it could be the heat controller too.
Make sure to recycle it properly if you do end up getting rid of it :)
von
Gas Valve Solenoid
Gas dryers have two or more gas valve solenoid coils. The gas valve solenoids open the gas valve ports to allow gas to flow into the burner assembly. If a gas valve solenoid fails, the dryer won’t heat. To determine if one or more of the gas valve solenoids has failed, check the igniter. If the igniter glows and goes out but does not ignite the gas, the gas valve solenoid is defective. If one or more of the gas valve coils are defective, I recommend that you replace them as a set.
Igniter
The igniter uses heat to ignite the gas in the burner assembly. If the igniter is not working, the gas will not ignite, preventing the dryer from heating. To determine if the igniter has burned out, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Flame Sensor
On a gas dryer, the flame sensor detects the heat emitted by the flame. If the flame sensor isn’t working, the dryer won’t heat. Before checking the flame sensor, first make sure that the igniter and thermal fuse are not at fault. To determine if the flame sensor is defective, use a multimeter to test the sensor for continuity at room temperature. If the flame sensor does not have continuity at room temperature, replace it.
Bewertung 0
@grayashlyn38 since this is an ELECTRIC DRYER and you already replaced the thermal fuse, the next things to check would be the heating element. Use a multimeter and check the element for continuity. If it does not have continuity, it is burned out and needs replacement. After that you want to check the cycling thermostat as well as the High limit thermostat. We would need to have your exact model number for more specific information on those.
Bewertung 0
Antwort hinzufügen
Ashlyn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 90
Insgesamt: 2,300
