Zum Hauptinhalt wechseln
Apples Smartwatch der dritten Generation mit optionaler Mobilfunkverbindung, veröffentlicht am 22. September 2017
197 Fragen Alle anzeigen
Apple Watch PCB repair
Hi!
Is there any board view for Apple watch series 1 - 6 out there? It’s missing from ZXW .. A need it because I want to repair a 38 mm Apple Watch Series 3 which has 1 component came off from the motherboard and I want to know what it is…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I can fix it what type of damage?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
hello Peter,
unfortunately, I don't think anybody has schematics for apple watches. I don't think they exist in the zone, and neither do the new iPad models. In such cases, we use experience and knowledge in the field of electronics. You need a good meter and some general knowledge in measuring passive consumer electronics. Unfortunately, to measure something and be sure that the measurement is correct - the element must be desoldered. Good luck :-)
It’s popular last times with the YouTube generation to buy "donors" - blocked ones and transfer parts without knowing what is that - I wrote about it above. This is a solution, but as you can see - it's quite short-sighted.
desolder, measure and email me, I’ll tell you some.
  • regards,
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you for answering! Thats what I thought :) The thing is the bord has very tiny water damage and the bad is corroded... This is a project I put on the side for now.... :D
von
I do I can fix it
von
I can fix it what type of damage dose it have?
Bewertung 0
Antwort hinzufügen
Peter Hupuczi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 492
