What is IDU mode on my PS4 I just bought used?
I bought a used PS4 and apparently it is a kiosk console and the guy refuses to give my money back. If I change out the mother board will the playstation work like normal?
Ist dies eine gute Frage?
I wouldn’t think you’d need to change out the mother board, I think a new Hard Drive would suffice. I don’t know how much you paid, but this could be an opportunity to upgrade to an SSD.
Follow the below steps to setup the new drive to use for ps4,
If your PS4 console does not recognize the update file, check that the folder names and file name are correct. Enter the folder names and file name using uppercase letters.
War diese Antwort hilfreich?
I actually have a kiosk model and reinstalling the retail firmware and changing hard drive does not work. It will install, just like a retail console, but then it will send you through first time set up just like a retail console except it will skip the PSN portion because it knows it's still a Kiosk console. Without a kernel exploit on an exploitable firmware, removing IDU mode isn't possible. With the kiosk PS4, you can still play retail disc-based games, and you can modify most settings in "Staff Mode". Though you cannot launch games from Staff Mode or connect to PSN, you must reboot, and launch your disc from with the OMSK interface without Staff Mode on. Once you're in a game, you can enable Staff Mode again.
Disconnect Internet Press L1 + L2 + R1 + R2 + UP + OPTION for 15 seconds to enter "Staff Mode". Go to the menu of the PS4. Launch the exploit. Go to the Debug Setting. Turn Off IDU Mode.
Thank you so much you are a life saver
You need to enter the debug setting, if you are on 7.02 or lower firmware you are lucky you can make it otherwise u have to wait
Hi thanx for your great Infos. But if you have 2 Ps4 models with FW 8.02 and one with FW 9.00 how can I start the exploid when Jailbreak is not possible for this 2 Firmware´s ?
is there no other way to get out of this f***ing Staff mode ?
if not I must sell the 2 ps4 in Parts.
Any tip ?
Theres now an exploit for 9.00, check it out on Cryptogenic github
Letzte 24 Stunden: 6
Letzte 7 Tage: 48
Letzte 30 Tage: 89
Insgesamt: 7,309
1 Kommentar
problem mod idu enabled for disabled solutions help me
=== Update (01/14/2023) ===
we have problems ps4 idu mod enabled for disabled
von نادر قاسمی
