Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 Fragen Alle anzeigen
My new 3DS volume is no longer working
I own a New Nintendo 3DS, never dropped it, never got it wet, always kept it in its case but I just stopped using it for a while. I decided to use it again and found that even if I move the slider, the volume stays super low. I’ve taken it apart properly to check if it was a slider issue but it isn’t. Is there anyway to fix it or is there a piece I can buy to fix it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@rsharky check the speaker ribbon cables and connector. You could try to connect a new speaker assembly (or for now just another speaker rigged to it) and see if that makes a difference. Also, check the audio jack and see if that works better/at all. If none of that works there is always a possibility that this is caused by a bad audio IC. Let us know what you find out with a new speaker first.
https://www.ifixit.com/Store/Game-Consol...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@oldturkey03 I checked the ribbon and connectors there was nothing wrong with it. I don't have additional speakers with me. However, I noticed that even when I connect headphones in, the volume is still low. Also would that speaker assembly work for a regular new 3ds, not the XL?
von
@rsharky "that even when I connect headphones in, the volume is still low" makes me think that there is something else going on. Let me see if I can get some more info on the audio IC.
von
Antwort hinzufügen
Rachel M wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 1,062
