Zum Hauptinhalt wechseln
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Fragen Alle anzeigen
Why do I get hE error code? Replaced thermistor and thermostat already
My Kenmore elite clothes dryer keeps running and displays an error code hE. It runs at one minute until it overheats and shuts down. It dries the clothes fine but with one minute left in the cycle it just continually runs until it overheats at one minute. I have already replaced of the thermistor and the thermostat and the heating coil.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
Hi,
What is the model number of the dryer?
von
We have this same issue. Our model #is 110.87872603
von
@movo62 so you get the hE error code as well? what have you checked?
von
we replaced the thermistor-but we are now just replacing the whole dryer. My husband is pretty handy and thought he had it fixed but it still showed the error code
von
Einen Kommentar hinzufügen
1 Antwort
First thing to check would be your vent. The model number would help - but that is usually related to overheating. Most of the time caused by a blocked vent. If you have replaced those parts already - try this option. Easiest way to test the vent? Remove the vent from the back of the dryer. Run a cycle empty and see if it shuts off like it should. If it does - clean that vent out, or just replace it!
Good luck!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
kl_peddie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 368
