Zum Hauptinhalt wechseln
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
Howdo I narrow down whether its the resistor or the speed control swit
I have power to the motor. And have checked it with voltmeter. Replaced the resistor. No luck there so I checked the speed control switch and it is melted a little on the connector and there isn't any resistance on the switch. I tried jumping the switch but nothing happened there either. So now I want to check the connector on the resistor. However I can't find an help with that.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @fordfun ,
Do you mean the blower motor resistor?
Here is an image from the repair manual, showing the circuit for a 2005 F150 auto and manual A/C blower motor and motor resistor.
(click on image to enlarge for better viewing)
Here is the rest of the repair manual in case you need more information.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Jeramie Millhouse wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 232
