Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
iPhone Microphone Issues - works on camera and Siri, but not on calls
Hello,
I have a similar issue to someone else on here, the microphones on my iPhone 8 only appears to work while doing specific things - the microphone works fine with Siri, Front and Rear facing video, but doesn’t work for calls on both speaker and earpiece, pretty sure FaceTime & voice memos records a flat line and plays a cracking sound. I am thinking it is the bottom microphone that isn’t working, and am hoping it is not logic board.
As for history; the screen and back are cracked (bought it like this) particularly near the dock section on the back. However, everything else works fine (as far as I can tell) and I opened the phone up and all water damage indicators are white and the phone is mostly clean with little dust.
Has anyone found a solution yet? I have ordered a new replacement housing with parts so it comes with a new dock connector and mic so I will see if that works!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Microphone is most probably disabled for phone calls. Go to settings to see if this might be the problem, or go to the phone app and check the setting there.
War diese Antwort hilfreich?
Bewertung 0
Bottom microphone might be broken or not making good contact with the logic board.
Bewertung 0
Antwort hinzufügen
TmG wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 64
Insgesamt: 1,751
