question about emi shield removal
i looked everywhere but cannot find an answer to what happens to performance, etc if you remove the emi shields.
Ist dies eine gute Frage?
Behind the very top screw of the emi shield is a small metal jumper/pin that creates a connection between the motherboard, screw and subsequently the casing - which increases WiFi antenna size.
Removing this jumper/pin has the knock-on effect of reducing wifi range to about 2 metres - i.e. you need to be 2 metres from a WiFi access point to see it.
Pictures (posted by another user on here) can be found at: http://s1215.photobucket.com/albums/cc51...
To my knowledge, as long as this screw/jumper are in place then there are no other performance downsides to removing the shield - though health reasons, I am not so sure :)
Source: Based on my experience of using my iPhone 4 for about 6 months without the emi shield, when this was the only problem I encountered. Was v annoying though so I have since replaced the parts.
War diese Antwort hilfreich?
Can you buy that pin that Rob was talking about because I lost mine when I replaced my LCD.
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 4,844
