Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
72 Fragen Alle anzeigen
bricked MacBook after upgrade to Big Sur OS
Bricked macbook retina I7 2017 after upgrade to Big Sur OS. Which part do I replace? Is this fixable?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
You’ll need to speak with Apple to log the issue and for them to fix your system.
Sadly, there isn’t any part to fix this that you can replace here.
War diese Antwort hilfreich?
Bewertung 0
i was able to revive mine (a different one - mid 2014 mbp with retina) by disconnecting the io board with hdmi, sd card slot, usb and wifi. apparently the reason is a conflict between firmware (?) and that card (possible cause in my view is inability to initialize all the bootable devices - sd card and usb are among those). ill try to downgrade firmware - should get that board functioning again…
Bewertung 0
2 Kommentare:
@arty_333 - Sadly the MacBooks don't have a separate I/O board like the Pro models. Thats why he will need to talk with Apple directly for an answer.
von
@danj that sucks... i would have never opened (and never knew what’s nside) mine if not for big sur ((
von
Antwort hinzufügen
arie137 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 153
