Zum Hauptinhalt wechseln
Is 2nd. Gen back panel interchangeable with 3rd. Gen?
Hello,
I have a 32 GB 2nd Gen Touch and the insides are basically shot. However, there is engraving on the back panel that I would like to save. Will the 2nd. Gen back panel fit on a 3rd. Gen. I thought since I have to replace all the internal components I might as well update them as much as possible. Would like to use a 64 GB 3rd. Gen if possible. Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I don’t know off hand, but i would look at the measurements of both panels, and see if they are the same. Even so, do this repair at your own risk.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the reply. The information I have gathered thus far says the sizes are the same. My real concern is whether the stand off for the screws that hold the boards/controls in place are in the same location. In this case, the reward is worth the risk.
von
Antwort hinzufügen
David Rawson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 52
