Zum Hauptinhalt wechseln
Drahtloser Kontroller für die Xbox 360
20 Fragen Alle anzeigen
Broken LT trigger Replacement parts
The little component of the circuit board which is activated by the LT trigger is constantly activated. I disassembled it and found all the mechanical functions of my LT button we’re in good shape. So I narrowed it down to the the component on the circuit board it was attached to. I was hoping to replace this component since it seem to be faulty, but when I looked online my problem seemed to be a one off thing. I then tried looking a circuit board diagrams for the part number. Didn’t find a good one for identifying the part. I was hoping someone here would be able to point me in the right direction to replace this part without replacing the entire mother Board.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Search “trigger potentiometer”, you can find them by the bunch.
Although it is going to be a difficult repair, you have to desolder it from the flimsy controller board, which often gets overbaked and traces will fall off the board. Also you have to mind not to melt other plastic parts.
If you can reach them, cut the leads off the potentiometer, disassemble the plastic parts, clean the leftover leads from the board and solder new one on.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you for pointing me in the right direction!
von
Antwort hinzufügen
Atomic Testing wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 30
Insgesamt: 496
