Zum Hauptinhalt wechseln
Released in 2017 the ASUS ROG Strix GL503VD is a high performance gaming laptop.
I turn it on, but in a few second, it turns off immediately
I really appreciate any kinds of help.
So i have Asus ROG GL503VD,
As i said on the title, i turn it on then in a few second it turns off immediately without even showing ROG logo.
Here are the events:
  1. I hold the start button
  2. The rainbow light below the keyboard starts glowing as usual, The light that show the battery condition (battery indicator light) is also glowing, The screen is still black.
  3. Soon after, it turns off immediately. Also, i heard a laser gun star wars sound effect in the process. The rainbow light & the battery indicator light are turned off.
Before this thing happened:
  1. I shutdown it by using start button (hot shutdown ? Idk the name really). I was in a hurry.
I’ve tried:
  1. Plug out ac adapter. Anyway, i still can recharge the battery. I noticed the battery indicator lamp turned red (means not 100%), so i recharged it for a while, then it came back to white (100%)
  2. Hold start button 40 sec
  3. Plug out the drive (hdd) (Only the hard drive local disk D, not the ssd one, which is the local disk C).
  4. Plug out the battery. It’s kind of complicated, because the battery can’t be plugged out easily (you know, there are some laptop that the battery can be plugged out easily, like you don’t have to open the body).
  5. Plug in the ac adapter
  6. Plug in the battery
  7. Plug in the hdd
I’ve tried so many combinations
5 then 2, doesn’t work
5 then 1, doesn’t work
4 then 5, doesn’t work
3, 4 then 5, doesn’t work
3,4 then 6,7, doesn’t work
3,4 then 6,7 then 5, doesn’t work
And etc…
Please, i need your help guys, i’m not an official tech guy, i know little about this thing…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Ok the problem is clear. The laltop turns off right away because its cpu fan is dirty and cpu overheats, unplug the power cable,, pull out the battery , press power button for 50 seconds, then get in hands powerful alcohol spray gun , ,position computer the way, that its radiator window would look down , shoot alcohol directly inside the radiator holes, try to spray to all radiator extentions, 2-3 minutes washing would be enough, Now the alcohol must dry out inside the motherboard for 2 hrs, Then turn on the computer and voila, everything will return back to normal
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Disconnect the main battery connector, as shown in step 4 second photo, but don’t bother removing the battery,
ASUS ROG Strix GL503VD-DB71 Battery Replacement
then remove the CMOS “coin” battery to the left of the main battery and press the power button to discharge all power from the system.
Put the coin battery back, plug in the power supply/charger and turn on the computer. Does it come on and stay on?
If yes then shut off, correctly, unplug power supply and reconnect battery. Does it still come and stay on?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Same issue initially, but after the CMOS battery trick as suggessted by Mike, lights won't even flicker.
von
Antwort hinzufügen
Dainsleif wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 48
Insgesamt: 3,344
