Vertical lines on TV. [T-con board or panel?]
Hello,
I have a Hitachi 50r5. Recently a vertical line appeared on the screen, but bow there are hundreds of them of different colors. Depending on the image, the lines remain in one way or the other. After a quick research, I found out that it might be the t-con board, but in the videos and pictures I saw, the lines were just a few. I would like to know if you can tell if it is the t-con board or the LCD panel.
I opened the tv and checked if there was any loose ribbon cable in the t-con board but everything looked fine to me.
Please see the attached images.
Thank you
Edit 1: It is worth mentioning that when I unplug the TV and plugin it again, the lines don’t appear immediately, they fade in except for the long horizontal line, that line does appear instantly.
Ist dies eine gute Frage?
