Zum Hauptinhalt wechseln
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 Fragen Alle anzeigen
I search a manual (with pictures) explaining the repair of a motor
Hello
i see a Suzuki FA50 Moped Teardown, and it's a very good repair manual !
But this Guide don't show how to repair (disassemble, and reassemble) the engine...
Does iFixit Team have a repair manual with pictures ?!
Or an other repair manual for an other Moped (or little Motorcycle) ?
My email is: elmikii@gmail.com
Cordially
Update
Hello Djuric
Thanks you for your answer !
I have look to your post about Throttle cable question, thanks you :)
I have look on autozone too, but i don't find any repair manual as well made as those of ifixit.com
What i'm loocking for is a repair manual of any motor as well made as those of ifixit.com, with picture step by step.
(if it's possible, for a moped for a small money value in order to train myself)
Do you know where i can find it ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Sorry amkgroupe, I did the Suzuki teardown as a fun weekend project -- I figured I could snap some photos as I was taking it apart.
I tried to be as thorough as possible, without actually going into portions of the engine where I could seriously screw things up. The real problem I was having with the moped was the stuck throttle cable. Check out this other Answers post on it: Throttle Cable Question
However, you may be able to find some motor repair information at Autozone. If you sign up as a member (free) and input a vehicle of your choice, they will display any repair manuals they have for the vehicle. The manuals may not be as good as iFixit's, but they will at least get you started. :)
Answer Update
Unfortunately the best advice I can give you at this time is to browse moped forums, such as Moped2.org, that may have some information on how to take apart a moped engine.
War diese Antwort hilfreich?
Bewertung 4
1 Kommentar:
I have post on moped2.org at this link :
http://www.moped2.org/forum/forum_posts....
We will see... ;)
Thanks you a lot Djuric
von
Hi Djuric
I have find the mope manuel for Suzuki FA50 Moped
at this link :
http://viewmorepics.myspace.com/index.cf...
When i start fixing apple laptop, i know nothing, and with a little courage
and thanks to your repair manual, and i succeed in it thanks to ifixit team !
Now, i'm looking for do the same thing in moped, and later motocycle.
Do you think you can do a manual (with pictures) explaining how to take apart a moped engine ?
Cordially
Bewertung 0
1 Kommentar:
Hello Djuric
I have found different answer on your moped forum very good thanks to Donp, thanks you very much.
For finish, this is my 2 final questions until i will buy this moped for (i)fixit :)
i know that for to take apart this moped i will need this tools :
8" Needle Nose Plier
10 mm socket wrench
12 mm socket wrench
14 mm socket wrench
Phillips #2 Screwdriver
Two 17 mm socket wrenches
So this are my 2 final questions for you :
1) For fix suzuki fa50 engine (motor) : do i will need others tools (wich one ?)
2) With ifixit guide, and suzuki fa50 tech manual, do i need other things to succeed to take apart the engine, or do i need to know (have) one last thing ?
Good bye
von
i have a '83 and have found a few manuals online:
1980
1986 manual, another 1980 manual and a partial wiring diagram
i hope these help...thanks to everyone else for the phots and engine explanations. i've learned a lot.
Bewertung 0
Antwort hinzufügen
amkpgroupe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 11
Insgesamt: 6,295
