Why is my intake and throttle body have a ton of oil in them
I had a leak in my coil tubes ( all 4 of them) I removed the coil packs and plugs like an idiot and all the oil went into the compression chambers . I got out what I could .I put them plugs back in and put gasket maker on the missing coil tube o rings I started the car and blew a ton of smoke through my exhaust . It stopped smoking then I drove it afterwords about 5 miles and I noticed leaking then the engine shut off . I took the plugs out again and the compression chambers were full again . I put a code reader on it it said my crankshaft pos was out and my camshaft. Pos was out . At this point the car starts after a while of cranking and pumping the gas but runs rough till it stalls out . If I change the pos sensors will this fix my problem with the oil . Ps . It doesn't smoke while running rough just spits and sputters
Ist dies eine gute Frage?
