Zum Hauptinhalt wechseln
Das Lenovo IdeaPad Yoga 11S ist ein 2-in-1-Convertible-Laptop aus dem Jahr 2015 mit einem 11,6-Zoll-Multi-Touch-Display.
How to replace back lid on Lenovo IdeaPad Yoga 11S
Back lid on my daughter’s Lenovo IdeaPad Yoga 11S got badly damaged and I purchased a brand new back lid. It seems that the battery or some other parts are somehow attached to the lid. Usually you just unscrew and open the cover, but it is not the case with this particular Lenovo. I tried to open it but it only opens halfway after I unscrewed all screws (even hidden behind rubber pads). Any help and detailed instructions are highly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Thank you guys! Your guides are exactly what I needed. Now I need to consider if I want to disassemble the whole laptop myself (and probably never make to work again) or to find a more experienced technician.
von
@esloutsky
If you take your time you'll be OK.
Also remember to disconnect the battery as soon as you can access it and reconnect it as late as possible in the re-assembly procedure to avoid any electrical problems when working in the laptop.
Also wearing an earthed wrist strap will help prevent any ESD damage. Try not to touch any components on the board that you don't have to anyway.
Good luck with the repair
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi
If you need a more detailed guide, here’s the hardware maintenance manual for the laptop, that will help with the dis-assembly procedures.
War diese Antwort hilfreich?
Bewertung 3
Referring to the below guide it looks like there is a pair of hidden screws beneath the keyboard, which is tricky but not uncommon. Does the below provide all the info you needed?
Best of luck with the repair!
Lenovo IdeaPad Yoga 11S Akku austauschen
Bewertung 1
Antwort hinzufügen
esloutsky wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 478
